All parts of a design or an order can be completely dimensioned with the function part dimension. In this process, drilling holes, working groups and hole lines are set with corresponding dimension lines and dimensions. The dimension module can be configured according to different requirements. Individual dimension data can be manually added with AutoCAD functions at any time.
Cross-section views are equally important for assembly and production. imos allows you to create cross-section views for any section levels. The cross-sections adjust and update accordingly to design modifications. The cross sections are clearly marked with material names.
Exploded views of every article can also be easily created for aiding assembly and design documents.
Customers and sales departments need a clear presentation of your plans or designs for sales negotiations. Additionally, imos also creates all necessary technical presentation drawings for discussions with architects, building owners or external manufacturers. Numerous functions are available for creating part and connection dimension or a 3D view with reduced design details.
